obd2 to obd0 HELP
Discussion in 'Civic and CRX - EW' started by krazyrikan86, May 14, 2008.
  1. krazyrikan86
    krazyrikan86 New Member
    herez my thing...i got a 91 CRX SI n im planning to do a swap but im confused about the wiring.....my crx is obd0 n tha swap is a D16y8 obd2 ......wut do i go about doing to make this swap work....ive searched high and low n found nothing of converting obd2 to obd0...can some one help plz and thank you!
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    What I would do is covert the crx to obd1 with a www.rywire.com jumper harness. I would then pick up a obd1 p28 ecu to run the new engine. You can convert your new d16y8 to obd1 pretty easily. You could get obd1 injectors or solder your obd2 injector plugs into your existing engine harness. You could get a obd1 distributor or convert the plug over. See what I am saying?
  3. krazyrikan86
    thanx for tha info...im grabbin my engine up tonite n hopefully with some werk ill be ON THE ROAD AGAAIN haha
  4. 1badasscrx
    1badasscrx New Member
    i have that same setup Y8 and have the jumper harness but still cand figure it out how to rewire it some pics might help me im desesperate to get my rex (work)
  5. efhondakid
    Akron-Canton, Ohio
    Caution: Old thread.
  6. alejandrosi
    alejandrosi New Member
    obd2 gsr swap into my 91 crx si
    hey wats guys up need. some help with my gsr swap into my crx si.
    i want to know if i should do ann obdo or obd1 to my crx.
  7. alejandrosi
    gsr swap into crx si
  8. Taco15
    Tallahassee Fl
    old thread.....but to answer your question do OBD1.
