OBD2 to OBD1 conversion
nwisehart
I have a 98 integra ls motor that I have swapped into my 92 honda civic. I am going to convert the engine over to obd 1 from obd2 before I run it. I was just wondering what parts I need to replace or change. The distributor, the injectors, the engine harness and what other parts do I need to change.
the dist, injectors, ecu
If you mod your obd2 harness you wont need to redo the whole thing and you can just get a 2 to 1 jumper for the ecu end
What do you mean by mod my obd2 harness? I currently have the obd2 harness on the engine and the car is obd1. The two harnesses plug together so do you think if I just get a 2 to 1 jumper and run an obd2 computer that will work fine.
