OBD2 to OBD1; should i do it
Discussion in 'ECU's, Electronics, and Tuning' started by isore, Apr 12, 2009.
  1. isore
    isore New Member
    ok so i hope i dont sound ignorant here, but crome and hondata only work with OBD1 right? I have an integra with OBD2a and i was wondering if i should convert or maybe theres a tuning program that will let me tune OBD2. and if i do convert will i need just the ECU and a wiring harness? I heard you have to do some craziness with the distributor... any info mucho appreciated.
  2. Briansol
    going to obd1 is the best choice.
    just keep your obd2 stuff around if you need to go to emissions, as the obd1 ecu will fail.
  3. isore
    isore New Member
    cool thx! so what do i need to do a FULL conversion. some of the pages i looked over suggested that all i need is an obd1 ecu and a ecu harness, but im skeptical. if anybody has a link i'd be eternally grateful!
  4. c-rex-beat
    c-rex-beat yeah, it's a vtec.
    tyler, TX
    yeah that should be it jumper harness and obd1ecu
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    run an obd2-obd1 jumper harness.get the obd1 ecu..and i think you will need the dizzy..
  6. oyy0
    oyy0 Sleepy...
    obd1 just has more options for tuning.
    keep your distributor and just change out the plug.
