OBD2 To OBD1 Swap
Discussion in 'HYBRID -> EG-EK / DC' started by butterdogg, Feb 13, 2003.
  1. butterdogg
    butterdogg Junior Member
    I Have a 1994 vx hatch and I like to swap a 1996 B18B into it. can I use the existing harnesses from my car? it is wise to do this swap? if yes, how!
    thanks in advance
    Eddie
  2. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    Just go buy an obd 1 distrib, ecu, injectors and you can use your stock harness.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I voted no poll,haha.Could he run a obd I ecu and call it a day?Can't you do that on the GSR's?
  4. ALLJDM
    ALLJDM Senior Member
    Tampa, FLorida
    see, I tend do disagree. I have an OBD II motor in my 92 Hatch, and I just plugged and played. NO cutting or nothing, and everything seems to be fine!
  5. SolReaver
    SolReaver Senior Member
    wrong- you only need the obd1 ls ecu. Why dont you tell me why you would not use the obd2 injectors and distributor?
    ALLJDM- :werd:
  6. Domeskilla
    Fort Wayne, IN
    Simply b/c when i started here, all i seen was "get obd 1 injectors, ecu and distrib". So i was wrong, i learned something.
  7. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    dude all you need is an obd1 ecu and conversion harness, skunk2 makes one and so do a bunch of people, check ebay i see a lot of obd2 to 1 conversion harnesses for sale there...
  8. xj0hnx
    C.C.TX.
    What would you need a conversion harness for,you can run it with a OBD I ECU and it all plugs up.
