obd2 Turbo?
can any one add someinput to this subject?
i don't see the issue here at all...
if you are buying an obd2-1 conversion harness... just unplug that and plug in the odd2 ecu with your n/a setup as well.
the dizzy, alt, injectors and all that will work just fine on either 1 or 2. its 0 that will not work
oh shit! no joke? didint realize at all not even a lil that it was that simple. for some reason in my head it was going to be a pain! i must have read something some where that i either misunderstood or was wrong all together
i guess so... :)
obd 1 ecu will work with 1 or 2 electronics
obd 2 ecu will work with 1 or 2 electronics
really, its the plugs that are different, and the call for the extra o2 sensor on obd2 ecu's. if you go to obd1, that wire to the 2nd o2 simply won't go to anything...
where can i find this obd conversion harness? and how much do they go for?
