obd2 vtec wiring
madteggy
does ne one now of a site or how to wire vtec on obd2a ecu in runing ls v so also for grounding knock sensor been looking every where n cant find the right one plzzzz help
.:FFS TechNet:. This site has it and it has pictures too.
So all i would have to do is wire the VTS, VTPS, AND GROUND THE KNOCK SENSOR WIRE since my po2 and so2 r already wire to where they go right and i dont have to worry about the iacv since its and obd2 integra if im correct can some one second that
what wiring harness are you using?
using ls engine and ls dash harness i wired the VTS The VTPS to the ecu and grounded the knock sensor I dont have any check engine codes but my vtec doesnt seem to kick in
my vts is good because if i tap it on the positive battery it engages but does seem to engage while im running I am using a virgin obd2 p72
