obd2 wiring harness or eg ex civic harness
Discussion in 'ECU's, Electronics, and Tuning' started by cooper, Jul 26, 2003.
  1. cooper
    cooper Junior Member
    i have a 93 civic ex and also a 01 obd2 gsr motor. the motor is already bolted in and ready to be wired. should i use the stock ex p28 ecu or use the obd2 p72 ecu that came with the motor. do i need to use the obd2 gsr wire harness or is there a way to make the ex harness work.
  2. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    The 01 GSR engine harness will plug right in.
    You will however need to add:
    Knock Sensor wires
    IAB wires
    Tach wire (factory tach will not work)
    Now, you have to ask yourself?
    Do I want IAB control?
    Yes= P72 OBD1 ecu
    No= P28 OBD1 ecu converted to DOHC specs
  3. cooper
    the whole harness in side the car all matches up?
  4. crxboi
    crxboi Junior Member
    Okay, I am doing something similiar to my 95 civic sedan. I have a 99 USDM B18C1 Engine, S80 Tranny, and the OBD2 ECU (dunno yet what model). Do i need to purchase a OBD1 GSR ECU? and what model should I get? I want the motor all stock (xcpt for normal bolt-ons). Does anyone have one that I could buy? Mahalo!
  5. pissedoffsol
  6. crxboi
    okay, stupid question, BUT what is a IAB? I am pretty new to the whole motor swap between different gens. Thanks!
  7. pissedoffsol
    secondary intake air butterflies in the GSR intake manifold.
  8. crxboi
    Thanks sol, Keep me in mind since I just got my engine, trans, axles, and the wire harness from that donor car. The guy who I am buying it from didnt have the OBD2 ECU so I dont know what model I have but, if anyone wants to swap OBD2 for a OBD1, I am game!!:D
  9. mathematics375
    mathematics375 New Member
    obd2 96-98 wiring harness
    I'm looking for a obd2 96-98 civic engine wiring harness, can anybody help?
  10. George777
    George777 ^^ Likes Bewbies
    With your mom
    Check the date on the thread, man. Just start a new one.
