ok, I know this its the normal swap everyone is doing, but i have a 95 LS Spec. Ed. and i'm goign to put a 2000 B18C1 in it using the '00 motor hanress and 95 nonvtec fire wall harness. Are the wires all in the same locations in the canon plugs between obd2b and obd1? And is there a different in the tach on OBD2B that u have to splice the wire into the icm wire to work in a obd1 ecu? I've been searching honda-tech and decied to come here, if its been discussed before if you have a link to the old post or any info it'd help, thanks
