khai_tuan_nguyen
I am putting an OBD2b GSR into a 95 hatch si. Let me know if I am missing anything. Here is what I am thinking:
I can drop the engine in, but I need to swap the distrbutor and alternator for ones that are OBD1. Of course I have to get mounts, axles etc.
Can I use the 95 SI harness? What do I need to wire. IAB, knock and what about vtec.
I shouldn't have to wire vtec, because it is the si harness and has vtec right?
Will the obd1 injectors work? since i am using the obd1 harness?
Anything else?
thanks
Anything else?
thanks
