Civic Dx 349
Im putting a D16z6 in place of a D16y8 and using my Y8 wire harness, Y8 intake manifold, and Y8 dizzy. Will this run correctly or will I have to go OBD1 to do so?
If I will have to go OBD1 for the car to run correctly what is needed to change my car to OBD1?
By the way, the Z6 motor does not have a knock sensor or crank speed sensor, unlike the Y8 motor. Will a OBD2b car run with out those 2?
If some one can break this down to me step by step to answer my questions, Id really appreciate it.
Thank you!
Thank you!
