RiceBurner98SC
Member
I was told that when wiring a USDM B18C1 into a 94 Integra RS, all I would need is to swap the motor, add the additonal wiring (4) and run a obdI p72 ecu. Now, I'm being told that I will have to use a obdI distributor because of the crank angle sensor. After reveiwing posts for days and artricles, Im a bit lost so to speak. So Im not sure as to what method to take. Any info would be appreciated.
