civicownzjuu
ok.. so i read the GSR swap into 95 ex coupe article that pissedoffsol posted in the articles section... BUT, that only helps if you get the harness with the OBDII motor...
what if.. i bought an OBDII b18c1 motor without the harness, but with the ECU... so this is what i would have..
B18c1 motor (OBDII)
D16z6 harness (OBD I)
GSR ECU (OBDII)
and everything else that is already in the EX (its wired for vtec n everything from the factory)..
So what do i need to make this work out... any help is appreciated!
B18c1 motor (OBDII)
GSR ECU (OBDII)
