OBDII code P1337 CSF Sensor no signal
Discussion in 'Civic and del Sol - EG and EK' started by mitch56, Sep 30, 2006.
  1. mitch56
    mitch56 New Member
    Can anyone tell me if the OBDII code P1337 CSF Sensor no signal is an easy fix or is it a shop issue.
  2. girls_are_mean
    girls_are_mean New Member
    utah
    Year? Car? for a 98 civic ex coupe all you need is a ohm meter to check for resistance between pins 1 and 3 (1.6-3.2k ohms) if its not that then replace the ckf sensor
    then check for ground from pin 1 and ground from pin 3 of the ckf sensor(it should be open when you check between the pins and body ground) if there is continuity, then replace the ckf sensor
    Then measure resistance between c1 and c11(harness side) if there isn't 1.6-3.2k ohms then fix your open wire.
    Then check for ground from c1(harness side) to body ground, if there is conintuity then fix the short
    keep in mind that this was the procedure for a p1337 on a 98 civic ex coupe
  3. mitch56
    mitch56 New Member
    The vehicle is a 1996 Civic, sorry I thought I had that in there. Does what you wrote apply to this vehicle? thanks for the write back. Mitch
  4. girls_are_mean
    utah
    It should yes.
    Just so you know what the code really is
    Diagnostic Trouble Code (DTC) P1337: No signal in the Crankshaft Speed Fluctuation (CKF) sensor circuit.
    Description
    The diagnostic system has a pulser rotor on the crankshaft and a pulse pick-up sensor on the engine block. The ECM/PCM monitors the crankshaft speed fluctuation based on the CKF sensor signal, and judges that an engine misfire occurred if the fluctuation goes beyond a predetermined limit.
    Could also try just clearing the code and seeing if it comes back on, it might be an intermittent failure.
  5. g_virux99
    g_virux99 New Member
    Hi, I just registered because I have the exact same code as the thread creator. I have a 2000 Honda Civic and I have code 1336, 1337. Please can you tell me if I can fix this myself with basic tools or must I put my car in the shop.
    For reference, the biggest job I did on my car is changing the timing belt (same honda as the one mentioned here)
    Thanks.
  6. CivicMan1
    CivicMan1 New Member
    I too started getting this 2 weeks after my timing belt replacement
    i had my timing belt replaced at McDavid Honda in frisco and 2 weeks later i started getting p1337. I have the same honda civic 2000 ex auto. What did you do to get it fixed. Did you take it to the machanic, if so, what did he told you it was?
    thanks
  7. dtob
    dtob New Member
    If your cars are still running fine and are not hard to start just clear the code and see if it comes back. If it comes back read above for trouble shooting. Someone already told you how to fix your car. READ!
  8. PAPA TEGGY
    PAPA TEGGY New Member
    yea can anyone tell me more or less were it would b located?...the ckf and csf i never messed wit tht b4
  9. PAPA TEGGY
