OBDII Code(s)
Discussion in 'Civic and del Sol - EG and EK' started by GlassHeadlights, Jul 23, 2009.
  1. GlassHeadlights
    Calgary, AB
    My dads co-workers girlfriends car spun a bearing so I swapped them in a new D16Y7. It drives great, idles like crap and it has a CEL. I have access to a OBD2 scanner but I don't know where to plug it into. I'll start with the code then go from there.
    Also I couldn't find the bleeder for the coolant system so that could be part of the idle problem.
    And Hondas over 1995 SUCK MY HAIRY LEFT KNUTT!! Shitty motors, hard to work on and not as reliable. My EF with 270,000 miles hits 6500 RPM and a D16Y7 that has 70,000 miles that hits 3000 RPM spins a bearing. The owner, a girl, has owned it from new in '99 and does EXACTLY what her manual says, also with every service @ Honda. WTF is up with that?
    Now where do I plug in the code reader? :D
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just count them yourself
  3. tabKola
    tabKola New Member
    Tewksbury MA
    There is a plug for it on the driver's side under the console, almost next to the hood release cable.
  4. GlassHeadlights
    Calgary, AB
    Shit, really? I know for OBD0 and OBD1 cars I can read them but for OBDII?
  5. AHHVTEC
    Alabama
    its the same, just jump the wires together thats in the plug on the passenger side. it will be a small 2 wire plug. long flash = 10s fast =1s
    1 person likes this.
  6. GlassHeadlights
    Calgary, AB
