OBDII head on OBDI block/chassis
f22b1 coupe
I bought a Teggy with a snapped timing belt, it's a 95 B18 (not a GSR, it's an LS or GS or whatever- special edition). There's a guy locally with a 96 head, and I was wondering if it will work, or will I have to modify something, or would it require an entire harness/ECU swap to make it work?
I haven't pulled the head yet, but sheez, I'd rather just put a different head on than tear down the valvetrain if it fucked up the valves when it went.
the heads are not obd specific- its the electronics on it. you'll just have to swap yoru stuff onto it.
