Please if someone can help me, I have OBD0 and I want to change to Obd1 what I have to do? I have a civic hatcback Si 1991 and I buy a LS/Vtec with b18A1 with a B18C1 head.
You will need a obd0 to obd1 jumper harness, you can buy one here Rywire - Online Store
The engine you are getting will need to have a obd1 distributor and obd1 or obd2 injectors. You will also need a knock sensor for it. The jumper harness comes with good instructions on how to wire all of this up including the vtec. Hope this helps!!
Also forgot to mention you will need the obd1 ecu, but i figured you knew that already. I recommend a p30 and some tuning with crome or hondata to get that ls/vtec to run strong!!
