odb 2 dizzy with p28
breed
why can't I use an obd 2 dizzy with a p28 ecu.
93 del sol si
01 JDM ITR engine
chipped P28
modified the stock del sol engine harness
swapped plugs for the distributor and injectors from the JDM ITR harness
used an OBD-1 B series alternator (or i could have just swapped the plug for that as well)
I did the same thing for my car and ran it off a obd 2 integra ls computer but I had no choice to put the p28 back in when I went with the vtec head. when I asked everyone said it can't be done but when I plugged the p28 in the car ran fine.
obd 1 and 2 electronics will interchange without a hitch (other than the plug differences)
