ODBI B18C1 into a 92 DX hatch....
hosmer
I made the millionth post
VIP
I've got a 94 GSR complete car.
I know can't use the DX engine harness, but will the Teg engine harness work, or do I need to get an EX/Si harness and run the knock/secondaries?
thanks
use the GSR harness
the 92 civics were all pre wired for VTEC so all you will have to wire is the secondaries and the knock sensor
and you only have to wire them from the ECU to the cannon plugs on the shock towers
everything else that you will need is in the GSR already (you lucky bastard :p )
sweet, thanks
you have no idea how lucky....
