Lets say you got a new gauge cluster from Honda are you allowed to use the odometer in it that's at 0000000 miles or do you havta use your odometer? and also is there a way to hook 2 odometers up at once? like maybe if you could cut and splice the original wires and run it to both so your orig and new one is still working? I'm just seeing if their are ways to start fresh on the odometer with a motor swap. thanks
