OEM Fuel Rails
Discussion in 'General Tech and Maintenance' started by MaaseyRacer, Apr 10, 2004.
  1. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    Can someone answer this are all OEM fuel rails them same volume wise? Are they interchangable? I have a b16 intake manifold, and I do not have a fuel rail, someone has offered me a super cheap complete GSR fuel rail. Will a GSR fuel rail fit on my B16 intake manifold?
  2. brian11to1
    brian11to1 Senior Member
    Pretty sure they are all the same. GSR is a bigger engine so it may be a tad larger. Go for it.
  3. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    honda fuel rails support up to I believe 400whp in terms of whether or not you need to compensate and buy a higher flowing fuel rail.
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    I am pretty sure that all honda fuel rails are the same, the only thing that is diffrent is the fuel pressure regualtor.
    Can someone reasure me on this.
  5. MaaseyRacer
    San Francisco, Ca.
    anyone else have any say on this as this rail is going to cost me next to nothign all i have to do is pay shipping as I helped this guy out a while back.
  6. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    I'm pretty sure it will work.
  7. cws13
    cws13 Senior Member
    Athens,GA
    That one should work but they are not all the same for sure. They changed them a bunch.
  8. MaaseyRacer
    San Francisco, Ca.
    how so? What are the differences between them, I just want something that is going to look stock, and function. I just know that the manifolds are different between some of the B series motors, and I just really want to make sure this is going to work.
  9. cws13
    cws13 Senior Member
    Athens,GA
    Wish I could be more specific, my experience involves people bringing in their cars to switch back to stock in order to sell or trade in. They usually left their stock rail at wherever shop they had the AEM one or whatever installed and bring in whatever they pick up cheap. Haven't had one work yet. I think the last one was a reg. Prelude rail trying to go on an SH.
  10. legutki
    legutki Senior Member
    It will definately not work!!
    J/K I have always heard they were interchangeable and it will it work By the way itwill be shipped tommorow :D
  11. MaaseyRacer
    San Francisco, Ca.
    sweet I got it, and guess what..... IT WORKS!!!! the GSR fuel rail is compatible with the B16 manifold, and injectors.. Thanks again Legutki.
  12. bklyneg
    bklyneg Senior Member
    los angeles
    i tried to switch one on my b20b and the holes that hold it to the intake manifold didn't line up. so , no , they dont all fit.
  13. Arachnid
    Arachnid Senior Member
    i think the b16a and the b18c1 are the same, b18b is different and maybe b18c5 is different (pretty sure it is!). b20 is out of the question, it's not even close to compatible.
