OEM Headgasket or Aftermarket...?
Discussion in 'Forced Induction' started by NeedACivic, Dec 8, 2003.
  1. NeedACivic
    NeedACivic Member
    Which do you choose and why? Also if you choose aftermarket please tell me what brand you would go with.
    P.S. The reason i ask is because i took my head off to replace my headgasket and to put in new headstuds to get ready for the Rev Hard kit this spring.(Its going on my JDM B18C GSR Hatchback). I plan to run 8- 12 psi.
    THANKS!
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    feelpro good seal and cheap
  3. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    just get 2 OEM honda headgaskets.
  4. NeedACivic
    NeedACivic Member
    Is there anywhere else where i can buy an OEM headgasket other than my local Acura dealership that way i can save some money?
  5. Joseph Davis
    Joseph Davis Member
    Last I checked Felpro was composite crap, inferior to the OEM metal gasket.
    I wouldn't worry about thick headgaskets or doubling up on stock ones, I'd just tune the car correctly from the go.
  6. pissedoffsol
    DO NOT run 2 gaskets. christ...
    just run the oem gasket.. thats all you need
  7. simplyfast
    simplyfast Senior Member
    there is a west minster honda dealership with a site that sells top end kits for $85, i suggest you buy that shit cause it will be cheaper in the long run. go with oem, its correct to the engine.
    i used cometic one time and i blew that gasket out around the layers...fuckin pos, ill never buy that shit again.
  8. 92civicb18b1
    feelpro isnt that bad...but comparing it to OEM, OEM is better.
  9. highperboi
    highperboi Senior Member
    Alameda, California
    Ive heard the mugen ones are reusalble if they dont blow
  10. simplyfast
    fel pro...fel pro is good.
    who told you mugen head gaskets are re-usable if they dont blow?
  11. MaliWho97
    MaliWho97 Senior Member
    No shit, they are collapseable.
  12. highperboi
    Alameda, California
    some dude at who owns a shop that went to a honda-tech meeting 2 weeks ago. he said if they arnt messed up and you take your head off for anyreason you can re use them.
  13. simplyfast
    i dont about mugen head gaksets, but, when you torque a head gasket down and the engine heats up, it crushes it to fit.
  14. Joseph Davis
    Joseph Davis Member
    Fel pro makes good domestic gaskets, but they use composite materials for their Honda gaskets. For FI, that is bad, mkay?
    OEM = steel.
