oem vavlve cover
Discussion in 'HYBRID -> EG-EK / DC' started by civic_types, Mar 10, 2004.
  1. civic_types
    civic_types Senior Member
    My cf hood does not fit anymore with my new jdm motor............... Is there a company which makes slimer valve covers....... or shall I throw on an oem hood........ maybe a oem cf hood ?
  2. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    one word...dremel.
    seriously.
    it's probably hitting on the front-driver's side corner of the valve cover. just dremel that bitch down (but not so much that you cut through the valve cover)
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Don't Dremel the valve cover, dremel the skeleton on the hood.
  4. civic_types
    It's a very skiney hood .............
  5. civic_types
    How thick is a valve cover ?
    It's like a two thousand dollar hood cdn........ Us it's probably $500.00 Usd
  6. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    Sell your hood and get an OEM style cf piece.
  7. civicious
    Houston, TX
    i was sayin dremel the valve cover over the hood cuz its CF, and prolly spensive as hell. it's more than likely hitting on the outer edge of the valve cover, which just covers the cam gears.
  8. civic_types
    Nah, it hits the front of the valve cover between the first and second cylinder..... guess I'm fucked, unless I just drive the thing, and see what happens.
  9. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    it's up to you, considering how much you paid for the hood, I would dremel the skeelton of the hood, if thta doens't work then sell it.
  10. xj0hnx
    C.C.TX.
    You don't Dremel the hood, you Dremel the skeleton (frame) it shouldn't be touching very much, and shouldn't require much material to be removed.
    What hood is it?, I have heard the quite a few don't fit with a b series motor.
  11. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Guessing it is a VIS hood? Yea, they dont fit b series swaps unless you cut a little off the skeliton.
    If you want, morsomo (sp?) sells a valve cover that claims to sit lower.
  12. civic_types
    It's an xr8ted lidds, invader hood....... but with a gasoline paint on it, changes color
