oem vs. aftermarket connecting rod bearings
Discussion in 'Engine Building' started by m2slsvtec671, Apr 21, 2004.
  1. m2slsvtec671
    m2slsvtec671 Member
    671Guam
    im just wondering which would be good.. a oem connecting rod bearing or a aftermarket connecting rod bearing (napa)???? or if i get the aftermarket ones, do ya think it will last long???? or just stick to oem....?? thanks!!
  2. 97CTR
    97CTR Senior Member
    oem all the way!!!!!
  3. hybrid89
    hybrid89 thistownsucks...
    SoCal
    a lot of people run ACL bearings also.
    matt
  4. welfare
    welfare Ancient Member
    New York
    Ok, if you want to go aftermarket, make sure they are GOOD aftermarket bearings. ACL seems to have good ratings, but from my experience, do not cheap out on the rod bearings. I had one engine with crappy aftermarket bearings I think they were sealed power or some crap, either way, they lasted about 4000 miles, then it started knocking. Go OEM if you want it to last, make sure you read all the markings on the rods and the crank so you get the correct color bearings.
    Dave
  5. 97CTR
    97CTR Senior Member
    If you are using the same crank and rods and just changing the bearings use the correct oem bearings to get the right clearances. ACL bearings are good bearings but they only come in one size, the equivalent to greens for honda. And if you want to do it right you should use plastigage to get the correct bearings and clearances for that rod or crank journal.
