oh no leakk !!!
chacal06
fuk men i been having this problem for a while i have a small oil leak on the corner of the engine not sure if its the head gasket or what because i recently changed it and it stoped but then now recently it started again :confused:
There is nothing you can do about it until you change the head gasket. There is nothing wrong with it, my b16 does it periodically. I've read that when you replace the gasket put a small amount of hondabond in the corner and the leak will stop.
