Oil Change?
civicblazin101
ok i think i striped that nut on oil pan which u unscrew to drain your oil. I was using a metric wrench. Does anyone know what size the nut is on a 94 civic? Metric/inch/size. Feal kinda domb but thats what the post are for. Thanks steve
My gf's 95 is 17mm, my old 91 was 17mm, my brothers 93 Del Sol is a 17mm. If you are using a stock plug it is a 17mm.
