Oil Consumption
Discussion in 'General Tech and Maintenance' started by lsvtec, Oct 21, 2002.
  1. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    My motor is eating oil fast. Like 1/2 quart every other tank of gas. I can't seem to figure out why. I replaced the pistons and rings with a cylinder hone about 2000 miles ago. I broke the new motor in for 1000 miles usign the proper engine break in procedure posted in the FAQ. The car puffs white smoke at high RPM (like > 7000) otherwise it does not smoke. I checked the VTEC oil line, it is not leaking or damaged. I can't figure out where the oil is going. Any suggestions?
  2. CRX-YEM
    Wallingford, CT
    valve stem seal, or valve guides might be leakin a bit
  3. lsvtec
    That is what I am thinking. Seeing how I have never replaced either can either of them be changed with the head on the motor? I think the seals can but valve guides cannot.
  4. CRX-YEM
    Wallingford, CT
    yeah the seal could prolly be done with the head bolted on the motor. but to do the guides, you gotta take the valves out completely. it'd be easier to do both at the same time.
  5. tb820
    tb820 Junior Member
    Get a leak down test done. That way you can determine exactly where you are leaking oil from. If you intend to replace the valve seals with the head still intact, set the specific cylinder to TDC before doing so. Make sure that you have a good hold of the valve when you remove the keepers, otherwise the valve will fall into the cylinder.... and that's a biznitch. I don't know, someone correct if I'm wrong, but you can also probably replace the guides at the same time.
  6. lsvtec
    As I thought to replace the guides you have to have the valves out, which means head off. Damn. It sounds like my head may be coming off next month.
  7. CRX-YEM
    Wallingford, CT
    naw the valves have to come out to replace the guides
  8. lsvtec
    Does a machine shop have to do it? If so this will wait until I can afford Skunk2 valves and do it all at once.
  9. CRX-YEM
    Wallingford, CT
    no you can do the guides your self it ain't to hard at all
  10. lsvtec
    Are the Skunk2 Bronze valve guides worth getting? I am planning to get Skunk2 valves as soon as I can afford them.
  11. knowledge
    knowledge Senior Member
    Beale AFB, CA
    I am planning on getting a whole skunk2 head package. I am getting the standard compression valves. I imagine the high compression valves kick ass! Skunk2 is like one of the top 5 N/A companies in my book! I am gonna see how well they work out for the turbo application.
  12. CRX-YEM
    Wallingford, CT
    I would say yes to the bronze guides. bronze for some reason (and I don't feel like gettin out the chem book) actually hold more oil on the surface than other metals I believe. I'll get a better answer for ya in a bit. Bronze I believe creates an ionic bond with some of the chemicals in the oil to create a better seal. they will last much longer as well
  13. lsvtec
    I know the website said that stainless steel valves wear stock guides down very quickly, but these bronze ones can stand up to stainless steel much better. All right, I think I have decided to get them even if I can't afford new valves at the moment.
  14. SolidDreamz
    SolidDreamz Senior Member
    va beach,pa,oh
    Are the valve seats and valve seals the same thing? If you replace the valve seals and the valves are worn out a bit, wouldnt it still leak? I pulled my head off to replace the head gasket and the car never smoked bad before, but i pulled the valves out and cleaned off the carbon deposits and put it back together. Now it smokes real bad. Is that because the carbon deposits could have actually have formed a seal on the valve so it seated right since the valves were old and now that i cleaned em thats why im blowing smoke out so bad?
  15. knowledge
    Beale AFB, CA
    No! The seals seal around the shaft of the valve. The seats seal the valve to the head in the combustion chamber. The valves shouldn't wear down like the seal will! Because you pulled the valves out and cleaned them oil is probably bypassing the seals. the deposits on your valve were probably helping to keep the seal between the valves and the valve seals. I would recommend you give it a week to see if it burns off. If it still smokes then I would replace the seals!
