S sevenhillsbilly New Member Oct 15, 2008 #1 how do i remove the jet from teh block it almost looks like its pressed in there is it a solid peice or is it just the o ring
D15Beater HNFTuning Oct 16, 2008 #2 its called running a drywall screw in there until it threads, then you pull it out, with some linemans cutters, pliers whatever you wanna use.
