eyesonlybob
well, i just changed the oil in my bros car. it was a quart and a half low. filled it up, started the car.
first thing that happened was white smoke started comming out of the exhaust. maybe 3-4 seconds, then it stopped. i let it run for a while sitting in the garage. and it started dripping oil. drain plug and oil filter are not leaking.
i guess thats a return hose or something. it goes into the oil pan. i cant tell what its comming off of. but thats where the oil is comming from. i guess most likey it has a hole in it. but what the hell is the hose called so i can get a new one?
and on to the worse problem. is it burning oil if white smoke came out of the exhaust? what kind of things should i look into? thanks
