Originally posted by lsvtec@Oct 6 2003, 10:40 PM
www.hondaautomotiveparts.com
They can get you all that you need. They claim to be able to get the Toyo-Roki oil filters. (Part number 15400-PR3-014 )
Originally posted by GSRCRXsi@Oct 5 2003, 12:32 PM
hey guys, it seems that my oil is leaking from my drain bolt on my oil pan. should i just get a new bolt and washer? i dont think its stripped. any ideas?
Originally posted by 94RedSiGal+Oct 7 2003, 12:05 AM-->GSRCRXsi@Oct 5 2003, 12:32 PM
How many miles on that oilpan? I had to replace my oilpan last year at around 220K miles. But for the last 120K miles I was having to use an oversized drainplug. I was getting my oil changes at my dealership, but the oil changing person (a former lotboy) was overtightening the drainplug... so I stopped getting my oil changes there.
So if your oil leak is not because of a lack of a fresh crush washer, then you probably have to go to an oversized drainplug.
Originally posted by GSRCRXsi@Oct 7 2003, 01:19 AM
hopefully its just the washer. like i said iven never replaced it, lol
Originally posted by lsvtec@Oct 6 2003, 09:15 PM
Have you replaced that crush washer? I find that if I do not replace that washer with every oil change mine leaks a little as well.
You don't need to replace those washers every time you change your oil! Do you? I have never replaced mine and I have never had an oil leak!
