Now I apologize if this thread is in the wrong forum. I have a B16A in my 1989 Hatch DX.
Okay, my drain plug is now leaking after so many oil changes. I am looking for a compatible oil pan for this engine. It is a JDM b16a! not a A2/3 engine. Now the plug still drips even after getting the drain plug tight. I have had it threaded once and I don't think threading it again is a good solution. What other oil pans out there are compatible with this engine? Also, my A/C belt snapped and I want to know which A/C belt from which model would fit in this car.
I believe I am 80% I should be looking for parts from a b16a2/a3 engine in regards to the oil pan and A/C belt.
Now I do want to convert my rear drums to disc. What donor parts should I be pulling from to make this work. I believe I heard somewhere in the grapevine that I should be looking at the 90-93 Integras but I am not sure if that information I got is correct or not. Oh and details on what parts exactly other than just the rotors is what I need. I plan on buying Power Slot slotted rotors for front and rear. So, I just need to know the parts other than the rotors for the rear drum conversion. Thanks for the help guys.
