oil pan fitment ...
Discussion in 'Engine Building' started by LS_VTEC, Jan 13, 2008.
  1. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Quick question that has been boggling my mind for the last few days...
    Will a first generation b16a oil pan work properly on a b18a bottom end? Also, will the oil pickup from the b16 flow enough? Ive always used the b18 pan/pickup, but my pickup is damaged and I have no oil pan now.
  2. dtob
    dtob New Member
    I'm pretty sure if you use the corresponding pickup for the pan you should be ok.
  3. LS_VTEC
    NJ
    I need a little more assurance other than "should fit". I guess ill contact a few sources and see what they say, monday.
  4. ls/vtechatch91
    ls/vtechatch91 New Member
    washington
    yes it will fit i have a b16 oil pan on my b18a1... im pretty sure there the samething.. but ya it will fit...
  5. LS_VTEC
    NJ
    Did you use the oil pickup from the b16?
    I am asking because my ls pickup is damaged and I will not use it.
    My b16 is a first gen. b16a. 1991 to be exact.
  6. ls/vtechatch91
    washington
    no i used my ls one.... they where the same if i remember right... my b16 was a 1st gen too...
  7. LS_VTEC
    NJ
    Alrighty. We shall see ...
  8. Sko0terMan
    Sko0terMan Member
    Los Angeles
    my first gen b16 oil pick up did not fot my b18b. i had use my b18. hope that helps
  9. LS_VTEC
    NJ
    thanks, I will most likely have to buy a new LS pickup.
