Oil Pan repair.
Discussion in 'General Tech and Maintenance' started by ovcrash, Aug 7, 2003.
  1. ovcrash
    ovcrash Senior Member
    Quebec, Canada
    Is it possible to repair a small hole in a oil pan? is there a way? Because i don't have the money to change it. And the hole is really really smal, but leaks a little bit. So is there a way, or something i could do to repair it?
  2. Loco Honkey
    Loco Honkey Banned
    JB Weld.
  3. ovcrash
    Quebec, Canada
    Please explain this?
  4. Trinity
    Trinity <font color=#FF909B><b>I go back like Aqua Net.</b
    Filthadelphia.
    go to advanced or a place like that. ask for jb weld or jb quick. its this great stuff that you mix together to form a everlasting bond
  5. ovcrash
    Quebec, Canada
    Ok! Thanks alot man..
    Thanks alot for the help! :)
  6. Trinity
    Filthadelphia.
    its ok
    ~ megan ( see..... not a man)
  7. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    yeah JB is good, but I would also consider finding out exactly where the oil is coming and then go from there.
    Milan
  8. WiggerMan
    WiggerMan Member
    JB weld is good or you could have someone with a welder do a quick little weld on it and it would be good for a while
  9. h82w8
    h82w8 Senior Member
    orlando,florida
    you can get this shit from the dealer called hondabond no shitting! my friend chipped a piece off his tranny and sealed it with hondabond.
  10. Loco Honkey
    Loco Honkey Banned
    That's assuming you have the piece.
    As for where the oil is coming from, he said he has a small hole in the pan. So, I would tend to think that the oil is coming from that hole. Weld it? Sure. But he's looking for cheap. A $5 tube of JB Weld is cheaper than $15 to spot the hole with a welder, and if you're really going to do it right, get a new oil pan.
