oil pan
Discussion in 'Forced Induction' started by turboef87, Dec 20, 2009.
  1. turboef87
    turboef87 New Member
    can u drive with a tapped oil pan just the drain line on it but no turbo i just wannna put this pan on already just want to kno if oil gonnna come out of the line illl have it up just like if it was on the turbo kinda stupid question but i dnt give a fuck lol
  2. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    if the line is plugged no problem, but I wouldnt reccomend doing it,
  3. efhondakid
    Akron-Canton, Ohio
    Why wouldnt you leave the stock pan on until its time for boost?
  4. turboef87
    1 less thing 2 put on
  5. hondacivicdx92
    hondacivicdx92 Hamby
    Indiana
    how does this work, either way u still have to install it:wtf:. wait till u go turbo
  6. phyregod
    phyregod !!YTINASNI
    Central Texas
    Just plug the line with something and put a hose clamp on it, it'll be fine.
  7. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    ^thats what she said
  8. solrocket1
    solrocket1 New Member
    akron ohio
    wow stupid just wait . prob the dumbest thing ive herd
  9. efhondakid
    Akron-Canton, Ohio
    fag
  10. esi42
    esi42 Member
    Why do something twice?
    Put the pan on witha new gasket, cut a piece of the same diameter heater hose as your tube about 2 1/2 inches long, plug one end with a bolt/metal plug/whatever, then hose clamp each side. Done.
    It wont leak if you do it right. Then you wont have to waste the money on another oil pan gasket and you reduce the chance of pulling threads from your oil pump or block since you are only torquing stuff once.
    Do what ya want though.
