oil pan
Discussion in 'Civic and del Sol - EG and EK' started by turbo sol, Jun 29, 2007.
  1. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    ok, so i bought a morroso deep pan for my sol and the bastard didn't mate up to my block... so i did what any hick would do, i ground the shit out of it trying to make it work. that didn't help, it just made it worse...
    so i got an obx pan for it and had the same problems...
    so my question is, does anyone know of a place on the net where i can pick up a deeper oil pan for my sol? it's a d16z6 and has a zc bottom end.
  2. badasscrx
    badasscrx New Member
    Casper. Wy
    were the hole just not lining up or was it the oil pick up tube
  3. badasscrx
    Casper. Wy
    he said its a d16z6 with zc bottom end but i dunno maybe his b and d got switched on his keyboard
  4. badasscrx
    Casper. Wy
    yes yes good idea for anything that does fit right
  5. turbo sol
    lol yeah, i should have called. but it is for the D16z6... i thought it was the pick up tube too, but it's not. what it is is the oil girdle, i'm no more than a half inch off. the bolt holes are lining up wrong (but not off by much. maybe 1/10th of an inch or so) and that damn girdle is in my way. it's sticking out and causing the pan to not fit flush. i can't seem to find a ZC deep sump pan. this is really pissing me off too... why the HELL is there a ZC bottom end on a D16Z6?
    and the really sad thing is that i just am noticing it after 10 months of the engine sitting out of the car, i even cleaned the bast and didn't notice it till this damn pan situation...
    does your z6 have a zc bottom end Blanco?
  6. turbo sol
    so i need a deep sump pan for a d16a6?
  7. turbo sol
    i need a deeper pan... i can get an extended pickup tube, but i need more oil. the turbo is oil cooled and my car has had some oil cooking problems. i just put in an oil cooler but that only increased the capacity to a little over 4.5 qts. i'm looking for 7 qts overall...
