SolidDreamz
I was told to take a 1/8 bspt fitted stainless steel line and hook it up to where the stock oil pressure sensor is near oil filter on a 00' gs-r and run it to a brass "t" fitting, put sender on one end and my fittings from my mechanical autometer gauge to the other side.
Is the "t" gonna be 1/8 on all sides?
How long should the S.Steel line be off engine?
Should i mount the "t" on the firewall?
Should i replace the crappy looking nylon tube that runs inside the car with S.Steel, or is it durable enough.
I'd appreciate the sizes the most, i hit up teamintegra.net and noone could give me a decent answer, they said just get an electric one.
last question does any1 know which wire on the ecu is the 02 signal wire?
Thanks very much for any help.......peace
