Oil Pressure light stays on...
Discussion in 'General Tech and Maintenance' started by raidmax, Nov 4, 2006.
  1. raidmax
    raidmax New Member
    East Coast
    93 Prelude... h22a swap... and turbo
    my oil pressure light stays on all the time! What are some things to check so I can fix it and turn off the OP light?
    Thanks,
    David
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    oil pressure-oil pump-make sure you got enough oil in it
  3. raidmax
    raidmax New Member
    East Coast
    I checked the oil.... it's good. Oil Pressure light still stays on.
    any more ideas?
  4. kkid28
    kkid28 He who burns the rubber.
    Regina, Saskatchewan.... Canada!
    Well my friends grandma had this problem so they just left it until the light burnt out :p Maybe you should try changing the oil. Also you could check the owners manual.
  5. raidmax
    raidmax New Member
    East Coast
    I've changed the oil.... and looked in the manual.
    maybe i need a oil pressure guage and see what it looks like. could the oil pump be going out? or do I need a larger one because of the turbo?
    I need a Air / Fuel guage also....
  6. GSRCRXsi
    MD
    if your oil light stays on, its either a bad pressure switch or you just dont have any oil pressure. but im gonna guess that you have no oil pressure.
  7. AHHVTEC
    Alabama
    i think he means the oil light not the check engine light,,the pressure switch would trough a check light
  8. raidmax
    raidmax New Member
    East Coast
    thanks for the help! yea the oil light is on not the check engine. What are some things to check? I'm kinda new to troubleshooting engines... :mellow:
  9. 93delsolsi
    93delsolsi Junior Member
    Jersey
    go buy and new oil sensor for 5 dollar at autozone
  10. raidmax
    raidmax New Member
    East Coast
    sounds good.... i put some "sea foam" treatment in my engine. It's now ideling really fast at like 2500 rpms @ a stop light :confused: I've checked all the vacuum lines and everything seems to be hooked up right?? Any ideas on why it's doing this now?
  11. klyph
    klyph Dismember VIP
    North Pole, AK
    If it was a fuel treatment, And your injectors were gunked up, it will take the ECU a while to smooth out the idle with your freshly cleaned injectors as they are flowing better now. The oil pressure sensor is what trips the oil light it doesn't trip the CEL. Put a new oil pressure sensor on and see if that fixes the prob. If that doesn't work, you're lookin at a new oil pump.
  12. kkid28
    Or somethings all clogged up.
