Does anybody know what size threads is on the block of a 91 prelude B20A5 where the oil pressure sending unit screws into the block i am trying to hook up a aftermarket mechanical oil pressure gauge i know the type of adapter i need is like a T-Fitting where you have a spot for your oil feed line and another spot for your oil pressure sending unit to screw into and then the other part is an extension that screws into the block but i dont know what size threads they are and whether they are metric or standard threads i tried 1/8 NPT and it would go into the block but i could not get the threads started nor could i get the oil pressure sending unit to screw into the adapter PLEASE HELP!!!!!!!
