Oil?
Must_B16
Hey guys I just checked my spark plugs in my D15b and I saw one of them had oil in it. And every time I look under the car I see a Bit of oil lay on the ground. I can't seem to see where its coming from. Might be a gasket leak?Anyone had this issue before? :confused: don't know what is causing this problem.
Check your valve cover gasket and see if that has a leak if it did than that would cause the oil on the spark plug when you take it out. If on the otherhand you have smoke coming out then that is a whole different issue
