Demented98
i live in canada im new to the forum and i have an american 1990 2 door 5 speed LS teg
i know alot about the car im on my third motor finally made the jump to b18b1 out of a 98 teg
i have a buncha mods so on and so on ...
ive searched everywhere for the answer to this and cannot find it
the 98 engine is all installed and running in my car on the OBD0 ecu and wiring ..
now my question is ... can i use the B18b1 intake manifold on my obd0 setup
people have said yes in other threads saying its easy so on ....
however theres no details as to what i use ..
1.can i use the b18b1s map sensor by extending my current wires ?
2.theres no where to hookup the two solenoids on the firewalls hoses for vacumn
3. can i eliminate the map and 2 solenoids on the firewall by using the b18b1s sensors already on it
4. if yes can someone give me a relitively detailed way to do this ?
reasons for my asking is a couple reasons ...
1. apparently the b18b1 intake flows better
2. my b18a1 intake is most likely wearing down and causing my idle to be crappy
3. i have strut braces for the back and front upper the back is in but the front seems to hit the b18a1 intake and wont let me bolt it up and the b18b1 intake is much smaller uptop so i can fit my strut brace on with no interference
4. without all the crap on the firewall and excess hoses it will look cleaner
im ready to do the install next weekend after i buy a new intake gasket any and all help would be appreciated
PS: theres also a black denso thing ontop of this intake manifold the engine was out of a 98 automatic integra if that makes a diff
the sensor from what i can find is an evep purge ? the numbers on it are as follows Denso 136200-1350 pcs7 can i use this on my obd0 if so where do i route it? if its irrelevant for the obd0 is there a way i can delete it and make the intake cleaner looking without that extra bulk ? thanks in advance
