Ok like everyone else pulsing idel
Discussion in 'Civic and CRX - EF' started by mikester1222, Apr 13, 2010.
  1. mikester1222
    mikester1222 New Member
    91 Honda civic dx with d15b dpfi injection I got a new idel control but still does it what's the potential problems?
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    low coolant level
    air pocket in cooling system
    bad PCV valve
    vacuum leak
  3. zach_teg_king
    zach_teg_king jdmzach "country boy"
    south central, KY (amishland lol)
    check your vaccum hoses for leaks and flush/bleed your coolant and radiator, replace thermostat, clean/replace fitv under throttle body with a known good one, mayb try replacing the iacv with a good one too.
  4. jlicrx
    Colorado Springs
    DPFI throttle body doesn't have a FITV
  5. mikester1222
    It was none of these it was the intake gasket and to find out if that's your problem get some carb cleaner and spray it around the intake gasket while the car is running. If the idel changes and makes a diffrence you need to replace the intake gasket.
