Old, but still worth mentioning.
Discussion in 'Members' Lounge' started by Loco Honkey, Oct 1, 2003.
  1. Loco Honkey
    Loco Honkey Banned
  2. Dustin_m
    Dustin_m Active Member
    San Diego, CA
    :worthy: :worthy: bad ass
  3. 2 litre EG
    2 litre EG Senior Member
    so cali
    hmmm i see something for the EVO!!! uh oh... sequential gear shifting for the evo... hmmmmmmm
    *evil laugh*
  4. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    what the conversion for yen
  5. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
  6. Frankie P.
    Frankie P. Senior Member
    Austin, TX.
    Do you still need to push in the clutch?
  7. ahedau
    ahedau Senior Member
    Middle GA
    do you still need to push the cluth? I'm sure...
    Price...figure about $1260 before 3% import tax & $195 s&h
    Total to your door...$1500.00
    Now THAT'S some expensive rice!!! :lol: :lol: :lol:
  8. hcivic.com
    what is the little lever on the right ?
  9. ahedau
    Middle GA
    reverse...
    according to the picture it takes two hands to do it..
  10. hcivic.com
    they look like two diffrent shifters?
    but that would suck trying to back outa a stall
  11. GSRCRXsi
    MD
    i dont understand how that can even work on a honda. since the linkage bar has to move forward and backwards. can anyone elaborate on exactly how it works?
  12. ahedau
    Middle GA
    me either...
    buy one and post some better pix with a techicnal breakdown of how it works. Might tackle as my next DIY project. :p :p :p
  13. jamesA
    it would work the same way, put the clutch in and pull the lever back, that'll engage the synchros whilest you pull it into the next gear.
    IT works good, ever seen the Focus or WRX rally cars?
  14. B16
    B16 Super Moderator VIP
    yay area, CA
    those are a little different dude, they actually use the paddles on the steering wheel, the sequential stick is for backup, but those trannies have 10's of thousands of dollars invested in them.
  15. ScrapinSi
    ScrapinSi Senior Member
    a true sequential shifter does not use the clutch.. I think this does though... i think with this you push the clutch and tap it... but you never know... I know a few people that can shift smoothly without the clutch at WOT... ;)
  16. djyox
    djyox Senior Member
    Twin Cities, Minnesota
    thing looks good to me.
  17. jamesA
    Right. they use the paddles, but for backup they use the floor mounted sequential ones, ever see em use the sequential ones? it works awesome.
  18. Celerity
    Celerity Well-Known Member
    Does that kit come with the gear readout? (The big LED number pad that shows what gear you're in)
    -> Steve
    Because I'm liking that.
    Found it does, sorry.
    Google is a wonderful thing.
  19. ahedau
    Middle GA
    Rally cars use compressed air to shift gears. The paddles tell it which way to shift & it does. There is an electronic signal sent to the throttle to stop the flow of gas w/out the driver lifting. Same thing as IRL, Indy, & F1 cars. You can get the same effect w/ a Hondata.
    When the air shift breaks they have to use the stick. When the margin of 1st-5th is only a couple of seconds over several miles of twisties, loosing the paddle shifter can make a big diff in a podium finish or not.
  20. ahedau
    Middle GA
    for $1500 for a bolt on it should come with a mechanic to install it.
