? On the z6 head
Discussion in 'HYBRID -> ED-EF / DA' started by rickscrx, Jan 2, 2009.
  1. rickscrx
    rickscrx New Member
    sevierville, TN
    i just bought a 90 crx it has a d15b2 block but has a z6 vtec head on it. the vtec is not hooked up but the motor runs good runs a little rich though. my ? is will not having the vtec hooked up hurt the motor or anything. also it has a ecu from a 91si.
    i am new to hondas so be kind to the new guy. thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    it could just get a vtec ecu and get it going right
  3. rickscrx
    rickscrx New Member
    sevierville, TN
    which ecu should i get. also the head has a td-02 dizzy on it know with 2 jumper wires going to the ecu.
  4. AHHVTEC
    Alabama
    just convert to obd1 and get a p28
  5. sevenhillsbilly
    sevenhillsbilly New Member
    and convert the dizzy too. the paper that comes with the jumper harness from wherever you get yours shows which wires go where thes only like 2 that are differnt if id doesnt let me know ill send you which ones go where and see if you can get the clips for everything too.
