Hi all trying to put my JDM b18c in my 95 civic ex coupe. So what I need to know is can I just unplug the harness by the towers and plug it into the towers on the civic? And the civic has the d16z6 in it now with the P28 ECU is there any wiring that needs to be done for the b18? And is it ok to use the stock P28 ECU? Thanks
the JDM harness is reverse of the USDM one so no it does not just plug in... you will need to either get a USDM harness or modify your D16Z6 harness you didnt say which B18C you are running (ITR or GSR) so you may also need to run the wires for the secondaries no a stock P28 should not be used for a B18C
Its a GSR. What modifications do I have to do to the D16 Harness? Just cut the plugs and splice em into my plugs?
