open loop VS closed loop ecu modes
Discussion in 'General Tech Articles' started by pissedoffsol, Dec 24, 2002.
  1. pissedoffsol
    ECU Modes:
    OPEN LOOP - this is the mode your ECU is in until the coolant temperature and a couple other sensors get to operating values. This is also true when you are at WOT or when throwing codes/ CEL's
    CLOSED LOOP - the ecu uses information primarily from the Oxygen Sensor and adjusts fuel delivery and timing to achieve minimum emmisions, better gas mileage and power.
