Ordering Motor
Discussion in 'HYBRID -> EG-EK / DC' started by davidzhou4893, Dec 10, 2013.
  1. davidzhou4893
    davidzhou4893 New Member
    Where should I order a motor/engine for my 1998 Honda Civic Lx? I'm looking forward to buy either a B16(A2,A3,B), B18(B1,C1,C5), D16Y8. Or what motor do you guys recommend?
  2. E_SolSi
  3. E_SolSi
    and for any recommendation we first need to know:
    what is your budget?
    what are your goals for this swap?
    what is the intended use?
    what is your skill level?
  4. davidzhou4893
    My budget is below 1500 I just need a new motor for my car to drive. I don't need nothing major. I brought the car couple months ago and the motor got blown.
  5. Matts96HB
    Matts96HB . Moderator VIP
    For that budget, a d16y8 is just about all you're going to be able to do from the list you have.
  6. davidzhou4893
  7. E_SolSi
    that is not even close to everything that is needed to get that engine in your car
    as said above go with a D16Y8 or just get another D16Y7 from a junkyard
    other than that you are going to need more money to swap anything in there correctly
  8. E_SolSi
  9. davidzhou4893
    What's the estimate on the motor b18b?
  10. davidzhou4893
    and how much would the labor cost?
  11. Matts96HB
    If you're going to have someone do it all for you, expect to pay at least $4k for the entire swap to be done. AT LEAST.
    Edit: What is wrong with the current engine? Fixing it might be a less expensive route
  12. davidzhou4893
    The engine I have currently is d16y7 and when I brought it, then had a mechanic to check it out they said it misfires. When i brought the car it ran good for about a week then it started to bog. Then i got it fix and ran good for another week then it happened again. Now the car bogs when it starts up, but recently it haven't start up it only cranks. The things I changed spark plugs, added helicoils for two cylinders, spark plug wires, fuel filter, fuel pump, ignition coil, thermal for fan that cools off the motor, oil change and that's all I could think of. Been spending a lot of money and the car still only cranks with no start. I have no idea where to start off to check for the issues/problems.
  13. davidzhou4893
    Also when I brought it, it had a lot of oil in the motor but its not leaking any oil. After the oil change it did not work after and I got the oil change at pep boys.
  14. 99sidude
    Ohio
    I'm willing to bet you don't need a new engine. Educate yourself and don't let morons work on your car.
    1. Are the grounds tight and attached?
    2. What error codes are there?
    3. Is the car getting spark
    4. Check for fuel pressure
    5. Check for compression
    No compression? Get a new engine.
  15. davidzhou4893
    I did all that myself, I been on forums and asked around researched. Except the oil change. Yes the grounds are tight and attached if your talking about the battery. I do not have a obd2 scanner so I'm not sure, and the check engine light on the dash is colored black so u cant see the light. I'm going to check the sparks tomorrow. I do not know how to check for the compression.
  16. davidzhou4893
    Someone I know told me that the engine is losing compression because of the first and second cylinder. The person that sold it to me stripped the first and second cylinder so my friend put helicoils on for me. After that it was running good for about 1 week.
  17. SlushboxTeggy
    NJ to MA to CA
    Buy an code scanner. It's like $80 for a cheap one. Keep the receipt if you want to bring it back, but I'll bet you end up keeping it. It's a useful tool. It also makes checking codes a breeze. No turning the power on and off and counting blinking lights. It'll make this diagnosis A LOT easier.
  18. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Or just go to Autozone, or O'Reilly's and they will hook up theirs and pull the codes for you for free.
  19. SlushboxTeggy
    NJ to MA to CA
    He said it doesn't start.
  20. davidzhou4893
    So I brought the OBD2 scanner and scanned it, no codes came up. I also used starting fluid and sprayed where the air sensor is and still only cranks. I checked if there was fuel pressure by untightening the screw on the fuel rail and fuel sprayed out.
