Over-heat engine block
Ivan323
Hi guys, i would like to find out if a engine block had been over-heated before, will it affect the performances n will it be less durable even if i already replace most of the internal like engine bearing,water pump,timing belt, gaskets, all kind of seals..
as long as it didnt warp it i have seen some pretty bad blocks b4 you might want to get the block and deck milled flat
