Overheating!!! Help!!
Discussion in 'General Tech and Maintenance' started by HonCiv99, Dec 30, 2008.
  1. HonCiv99
    HonCiv99 EK Swappa
    UT
    My B18c is overheating constantly now. I just changed out the thermostat last night, and the fan does eventually come on when the temp is at the very top. So I don't think the fan switch is bad. The rad cap is perfectly fine, there are no leaks in the hoses or the rad itself, and the coolant is filled up. So what could the problem be?? Any suggestions?? Thanks for the help.
  2. reikoshea
    Dallas, TX
    bad temp sensor. air in the lines maybe?
  3. HonCiv99
    HonCiv99 EK Swappa
    UT
    Yea I thinking of getting the system flushed out.
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yeah sounds like the temp sensor,i would try that first
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    clogged system,air,bad temp sensor,could be a nuber o things
  6. AHHVTEC
    Alabama
    water pump would be my next guess
  7. HonCiv99
    HonCiv99 EK Swappa
    UT
    It has a reletivley new pump on there. So I don't think that would be it, and its running fine so I dont think it would the head gasket.
  8. serrilion
    serrilion In my own little world! VIP
    Vermont
    Crack and Egg open if it cooks on the Head cover ya got a problem, if it take awhile to cook everything is good... But we all kno how reliable a Honda Temp Sensor is lmao... Another thing to check is how good is the oil in the motor? bad oil can cause alot of frichion hehe!
  9. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    you might have air in your system,
    a good way to get the bubbles out is use a funnel and add your antifreeze with the small hose from the head to the heater core.
    when your temp guage is reading high try turning on your heater on high and out side, full heat, the guage should go down.
  10. DESPAIN
    flower mound TX
    clogged system try draining your rad. and get a sys. flush
  11. SneakyTouchYourPlace
    SneakyTouchYourPlace New Member
    Also you can try putting your hand on the engine. If it really really really hurts it might be bad, if it really really hurts then everything is good :)
    But in his way, you kill 2 birds with one stone. Diagnosis and oily breakfast!;)
  12. INJEN78
    INJEN78 HS LEGEND
    OHIO
    WTF are you talking about???
  13. SneakyTouchYourPlace
    I was pokin fun of serrilion's comment. Never heard of diagnosis by cooking eggs.
  14. AHHVTEC
    Alabama
    its been one for over 50 years
  15. INJEN78
    INJEN78 HS LEGEND
    OHIO
    newbs!!!!
