Overheating Problem
Discussion in 'General Tech and Maintenance' started by deanpier, Jun 27, 2005.
  1. deanpier
    deanpier Junior Member
    Hey guys, I'm new this forum.
    I'm having on over heating problem with my 94 accura integra (not the vtech), recently when I drive it on the express way when its very hot (8o and above) the car starts to get very hot , the temperture gauge will start rising past the mid point moving towards hot, the air conditioning stops blowing cold air it turns to luke warm (checked freon ok) And when I pull off the express way the temp gauge goes back :( to about the mid point at lower speeds? I flushed the radiator and changed the thermostat twice. (New radiator about four years ago).
    Any suggestions would greatly appreciated,
  2. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    It sounds to me like your Radiator man....even though you replaced it 4 years ago...
  3. abdelsol
    abdelsol Member
    There is a bleeder screw to remove air. That may be the problem. The bleeder screw is located on the thermostat housing.
  4. Estorvito
    Orlando FL
    ^^^ That Too!
    Ohh and By the way..WELCOME to HONDASWAP..... :p
