overheating
1slowcrx
yes i have a 95 honda accord lx i have a problem my cooling fan is not turning on ive tested the fan with to wires to the battery it works ive replaced the cooling fan switch on the thermostate housing and i have tryed relays from a 94 honda accord ex vtech but it still would not work please help
I know that this is an old post so I dont know if you figured it out yet??? I would check the original wiring going to the fan. Also is it the condensor fan or radiator fan not coming on? On some of the accords there are more than one switch on the thermostat housing, are you sure you replaced the right one? Test your old switch on the other accord you have. let me know.
