Overheating?
twatson said:
did u fix this problem? is the motor actually over heating? or is ur gauge just fucked? the guage just might be a bad ground, its its actually over heating. its either your timing or ur thermostat.
The car isn't overheating if the timing doesn't skip. The problem is that it keeps skipping and I don't knwo what it is. The spark plugs,wires,distributor seems fine but the timing belt keeps skipping.
Inspect the cam gears are they worn? are you appling enough tension?
